6509 to 3560 connection
Aug 13th, 2008
I'm getting mixed results trying to get a 6509 to talk to a 3560 via 2 copper ports channeled together. Not sure how to explain this so the right question comes out.
We have a large number of vlans and vtp is setup and working. However, I cannot get one vlan to work right on the 3560.
I can get the 3560 to either work fine with just the one vlan (705) or it will work fine for every other vlan but the 705.
The two are connected via 2 gig copper connections. 2/45-46 on the 6509 and g0/1-2 on the 3560.
Taking all the info out of the equation above, can someone reply with the commands needed to do this connection like you had just bought the 3560 and plugged it in? From there I should be able to tell what I messed up.
thanks
Mike
Overall Rating: 4 (1 ratings)
Marwan ALshawi Wed, 08/13/2008 - 16:01
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
for vlans
if its the client in the vtp
just
vtp domain [domain name]
vtp mode client
if it is server make it server
and then creat ur vlans
like
vlan 2
name vlan_2
then
for the trunk [ etherchannel]
interface range g0/1 - 2
switchport trunk encapulation dot1q
switchport mode trunk
channel-group 2 mode active
no shut
interface port-channel 2
no shut
and the config in the other side [ other switch] must be identical regarding the channeld interface and encapsulation and trunking
good luck
please, if helpful rate
mlaporte Wed, 08/13/2008 - 16:45
Thanks for the reply, I have it running again, the only problem I have now is that I can't ping any devices on a particular vlan.
Marwan ALshawi Wed, 08/13/2008 - 17:05
u mean u cant make a ping between devices withing a vlan or between two vlans?
either way
post here ur vlan configs and i will assist u to solve it
thanks for rating :)
mlaporte Thu, 08/14/2008 - 06:30
Thanks for your help, I'm able to ping now and I think its mostly due to my inexperience with the vlan design here. They use vlans differently than I have in the past, I used them to cut portions of a chassis out for port density issues.
I've had to assign a single vlan to a port to get it to work :
interface GigabitEthernet0/11
description LFT Failover Manager
switchport trunk native vlan 705
spanning-tree portfast
Somehow I thought that if you plugged a device into it with a hard coded ip and the vlan was known by the switch it would route properly.
