Second switch module 4ESW - VLAN performance issues
Aug 13th, 2008
I have a Cisco 3825 router running 12.3(11r)T1
It originally had a single 4ESW switch module inserted into it. The customer likes each VLAN to have its own interface for routing. The customer currently has 4 VLANs and required the addition of another VLAN. For other customers I would normally use a trunk from the core switch to the router and just add the additional VLAN but as this customer insists on a spearate physical port for each VLAN. They supplied another 4ESW module.
I added the second 4ESW and linked them together using a cable. I had to move one of their existing VLANs from the origianal 4ESW to the new 4ESW to free up a port to connect the two together.
The VLAN I moved to the new 4ESW had some servers on. (VLAN 999)
See config below showing the stacking partners defined on the two cards.
interface FastEthernet0/0/1
description stack link to f0/1/3
switchport stacking-partner interface
interface FastEthernet0/1/3
description stack link to f0/0/1
As soon as I moved VLAN 999 to the new 4ESW the customer began to complain about server file transfer performance from all VLANs to and from VLAN 999. I did some testing and proved that the data rate was about 1/10th of what is was when the server VLAN 999 was on the original 4ESW. I moved the VLAN back to the original 4ESW and the data transfer rate went back to its original rate.
Anyone got any ideas of why this would be occuring. I checked the physical and virtual interfaces and there were no errors or indications to why performance should be degrated.
Barry
Richard Burts Thu, 08/14/2008 - 04:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Barry
Is there any chance that there is a duplex mismatch?
Rick
ukmailserver Thu, 08/14/2008 - 15:08
No. I checked and they were both talking at 100 full duplux. I did hard configure them later to try and see if auto/auto was causing any problems. The interface statistics were showing no errors. This is the wierd thing about it. No errors anywhere.
Cheers
Barry
