Farrukh Haroon Wed, 08/13/2008 - 18:48
  • Red, 2250 points or more
No need to change anything with the license during FWSM upgrades (unless this is a corner case). Just check the release notes for 3.2(7) just to be sure.
Farrukh
robertson.michael Fri, 08/15/2008 - 14:12
  • Silver, 250 points or more
Hi Gurpreet,
Farrukh is absolutely correct. There is no need to change the FWSM's license when upgrading. The license is simply tied to the FWSM's serial number, not the software version that you are running.
Hope that helps.
-Mike
gurpreetkohli Fri, 08/15/2008 - 18:51
Hello Mike,
Thanks for your email. I was also thinking along the similar lines but some created dought in me mind. Thanks again for your help.
