bwilmoth Tue, 08/19/2008 - 08:29
  • Silver, 250 points or more
You can try show version command,and also show diag command. You will get the output like ( Just a part of output)
System/IO memory with parity disabled
8192K bytes of DRAM onboard 16384K bytes of DRAM on SIMM
System running from RAM
7K bytes of non-volatile configuration memory.
