CDR for only specific Dialing
Aug 13th, 2008
I am using CCM 4.2(3) and mgcp gateway in IPTelephony setup. I enabled CDR and now i can get report for All Calls based on CMC or other criteria. My question, is this possible i just enable CDR for specific calls like for specific Route Pattern. Actually i enabled CDR only for international calls so that i could bill based on CMC and want to get just international calls report.
Waiting for your positive response.
Best Regards
Jaime Valencia Sat, 08/16/2008 - 06:34
no CDR, is for ALL calls and cannot be configured to log only certain information
java
if this helps, please rate
sameer.abuasal Sat, 08/16/2008 - 10:52
actually ramez , no you cant have CDR for only a specific route patterns , but if you really need this iguess you can configure the call manager to generate CAR reports for calls to a specific route pattern
Good Luck ;)
