AnyConnect VPN client can not uninstall automatically
Aug 13th, 2008
My ASA version is 8.0.4, and I have setup "Keep Installer on Client System" to "no" in my SSL VPN Client group policy, but the AnyConnect VPN client can not uninstall automatically after I logout from Clientless SSLVPN portal and / or disconnect AnyConnect VPN client. Can you help to resolve this problem?
Best Regards,
Jackson Ku
Farrukh Haroon Thu, 08/14/2008 - 00:53
Perhaps it would be nice to run webvpn debugs on the ASA and check them (or post them over here).
Farrukh Haroon Fri, 08/15/2008 - 06:57
Jackson, there is no helpful information in the debugs you sent. Are you sure your users are landing on the same group-policy in which you have opted to remove the SVC client after disconnect?
