IOS upgrade through RME
Answered Question
Aug 13th, 2008
I am using Cisco Works 2.6, RME 4.0.5 and want to upgrade the IOS of a WS-C3750-24TS-E switch. I have downloaded the IOS "c3750-advipservicesk9-mz.122-25.SEE4.bin" from cisco and added it to software repository through rme->software mgmt->software repository->add.
Now I selected the IOS and selected update status after which the IOS status changed to "not deffered".
Now to upgrade the ios on switches,which are detected as "Cisco 3750 Stack " , chossing software distribution -> by image . Then selecting the same IOS and device from select image and device window. after selecting next it shows me device name , module information and storage option properly. On the next step in verification window I am getting the following errors in verification details...
testsw
File_Name : /c3750-i5-mz.121-19.EA1d.bin
File_Size : Unknown
Family : C3750
Version : 12.1(19)EA1d
BOOTROM : Bootstrap program is C3750 boot loader
RAM : 134209536
Feature : LAYER_3|MIN_DRAM_MEG=64
Media : RAM
Image_Type : SYSTEM_SW
Software_Name : C3750-I5-M
SOURCE : flash:
UPGRADETYPE : ACTIVE
Flash Information
Flash Name : flash
Flash Size : 15991309
Flash Free : 11938304
Verification Errors And Warnings
SWIM1063: Minimum RAM requirement of the selected image cannot be determined.
RAM available on the device may not be enough to activate this image.
Update the minimum RAM value using View/Edit Image attributes or
make sure that the device has enough RAM to activate the selected image or select a different image.
SWIM1110: .bin images are not supported for Stack Upgrade.
Select a tar image for Stack Upgrade.
Pls let me know where I am wrong and what exact I have to do the upgrade IOS.
Correct Answer by Sven Hruza about 8 years 11 months ago
I think you should download the tar-file of the IOS you want to use like the error SWIM1110 tells it.
Because the Stack-Switches can't use bin-files.
Sven
Overall Rating: 3 (1 ratings)
Correct Answer
Sven Hruza Thu, 08/14/2008 - 00:59
  • Bronze, 100 points or more
Sven
Sven Hruza Thu, 08/14/2008 - 04:28
In the repository you can select the IOS.
There you can modify the "Minium RAM" and "Minimum Flash".
This informations you can get from cisco.com I think.
Then the first error message should be fixed.
Sven
Satya Siba Sund... Sat, 08/16/2008 - 15:40
Thanks sven..
well I resolved the problem . It was only because of that .tar format image. I had downloaded that from cisco site and upgraded the IOS of that switch.
