Error 413 after upgrading to vpn3000-4.7.2.P-k9
Aug 13th, 2008
I was'nt able to connect with my Cisco vpn client vers. 5.0.01.0600 to 3000 Conecentrator after upgrading image from
vpn3000-4.7.2.F-k9 to vpn3000-4.7.2.P-k9. Can any one help on this issue? Tanks in advance.
sfanayei
Farrukh Haroon Thu, 08/14/2008 - 02:03
  • Red, 2250 points or more
Double check your authentication credentials both at the VPN Client and the concentrator:
Reason 413: User authentication failed.
Description or Action:
Either the user entered wrong user authentication information, or the client was not able to launch the XAuth (user authentication) process.
Farrukh
sfanayei Thu, 08/14/2008 - 02:10
I found out that when i remove "Group Lock" check than i can Authenticate with Radius server. If I check the "Grou Lock" than Authentication fails.
Sfanayei
