What can we do on a switch /switching
Answered Question
Aug 13th, 2008
What can we do on a switch?
Is there a link that can explain all technology that can be implemented on a switch ?
Best regards
Correct Answer by garytayl about 8 years 10 months ago
Only thing close to it that I'm aware of is the Product Advisory located at:
http://cisco.com/en/US/products/hw/switches/products_category_additional_resources.html
After you finish with a couple of initial requirements, you can check all or some of the switches and hit on "Compare" that will give you a list of "features" you may use as a checklist.
Hope it helps...
Overall Rating: 4.1 (6 ratings)
Marwan ALshawi Thu, 08/14/2008 - 01:42
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
u asking about a broad thing
u can do routing
u can do switching
u can do filtering
u can add firewall modul do firewalling
u can do QoS
u can do policing
u can do trunking
u can do power over ethernet
u can do pact capturing
and so on ....
connect101 Thu, 08/14/2008 - 07:51
Thank you for the reply.
And now What can I say to my customer,
What can I do that the customer will understand these technology.My customer don't know thecnical language.
connect101 Wed, 08/20/2008 - 09:49
Thank you,
If I want to do the High Level Design, then I have to do a site survey.
So I will ask the customer about their need.
And I won't ask them with a technical language (VLAN,STP,COS...) but with a comprehensible language.
Is there a checklist somewhere about switching.
With this checklist I will be able to determine the exact technology that I will implement for them.
Best Regards
Correct Answer
garytayl Wed, 08/20/2008 - 10:17
  • Silver, 250 points or more
Hope it helps...
