NEC 2000 Integration with Cisco H323 gateway
Aug 14th, 2008
hi there,
we are trying to integrate NEC 2000 IPS with Cisco3845 voice gateway using QSIG.
We are able to get the E1 link up with ISDN status as Multiple frame established. But when we are trying to place call across this E1, we are getting " Recovery on timer Expiry" error message.
Similarly when We try to initiate call from NEC side, they can see the Trunk is seized by looking at the E1 card indicatio, but we are not getting a single packet on Voice gateway side.
TAC confirmed CISCO side confiuguration is correct and asked us to check NEC side.
Does any one have any idea about NEC side configuration? Will this be conpatible?
Any help is highly appreciated.
BR,
sachin
sachin.mahangade Thu, 08/14/2008 - 08:35
Ok.. there is one update now.... we are able to call from NEC to Cisco side ... but other way still having same problem...
sachin.mahangade Thu, 08/14/2008 - 09:04
also we have changed from QSIG to ISDN i.e. pri-net5 ... some how NEC is not replying when calling NEC extesion.
Tim Smith Tue, 08/19/2008 - 04:23
  • Silver, 250 points or more
Check the version of QSIG you are running on the NEC
What CCM version is it?
What does the debug isdn q931 look like
Cheers,
Tim.
sachin.mahangade Tue, 08/19/2008 - 04:58
we have removed QSIG and now using ISDN PRI-Net5.
Debug ISDN q931 gives below output:
*Aug 14 16:58:27.571: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 3005
*Aug 14 16:58:27.575: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x00E6 callID = 0x8025 switch = primary-net5 interface = Network
*Aug 14 16:58:27.575: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00E6
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Display i = 'Shaffeer Kunhimoideen'
Calling Party Number i = 0x80, '3005'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '2028'
*Aug 14 16:58:31.575: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00E6
Sending Complete
Standard = CCITT
*Aug 14 16:58:35.575: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00E6
Cause i = 0x80E6 - Recovery on timer expiry
*Aug 14 16:58:35.575: ISDN Se0/0/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK. The SETUP failed.
