VLAN puzzle
Aug 14th, 2008
Hi All
Something strange that needs explaining. I configured an interface to a particular vlan 10 and it does not work but i change the vlan and it works.
I change the blade, the switch and still the same issue. As long as I put it in vlan 10, it will not work but put it in vlan 11 or 12 or any other vlan, it will work. What can be going wrong?
smothuku Thu, 08/14/2008 - 01:28
  • Silver, 250 points or more
Hi ,
Did you create Vlan 10 on the switch.Anything is connected in Vlan 10.
After creating Vlan 10 , you need to assign it to any port so that you can pulgin eitrher PC or Server in that Vlan.
As soon as you create vlan , it willn't comeup until unless something is placed in that Vlan.
Can you paste the "show run" of the switch.
satish
qwertys21 Thu, 08/14/2008 - 01:36
Thanks. There are a lot ofm devices already in vlan 10.
There are devices in all the vlans.
smothuku Thu, 08/14/2008 - 01:38
Hi ,
Can you paste "show vlan " output.
What is the model of the switch.
Txs,
Satish
qwertys21 Fri, 08/15/2008 - 04:38
Thanks. I think the network was just being quirky. I came in the next day and all was fine. Strange. Thanks for your help. REally appreciate it. Cheers
