ASA-IPSEC L2L with GRE Tunnel doesn't work
Aug 14th, 2008
we have a asa-asa connection between 2 buildings with ipsec and a gre tunnel between them because we use eigrp for this network.the tunnel is ok works perfect but i get syslog messages like :
Aug 13 17:04:54 FWH50031 %ASA-4-313005: No matching connection for ICMP error message: icmp src outside:134.81.191.233 dst inside:134.81.227.78 (type 3, code 4) on outside interface. Original IP payload: <unknown>.
Aug 13 17:05:04 FWH50031 %ASA-6-602101: PMTU-D packet 1462 bytes greater than effective mtu 1434, dest_addr=134.81.191.178, src_addr=134.81.227.78, prot=GRE
and we don't find anything about on cisco to adjust the PMTU-D size on the GRE Tunnel.
(net)-(tunnel-gre)--(asa)--airconnectinon--(asa)--(tunnel-gre)-(net)
Farrukh Haroon Thu, 08/14/2008 - 02:07
Try this on both routers:
interface tun X
ip mtu 1400
ip tcp adjust-mss 1360
You have to set this on both ends.
Farrukh
ksimsimon Thu, 08/14/2008 - 02:19
Hello Farrukh,
thanks for the fast response.
the command ip tcp adjust-mss 1360 does't work on both routers. its a 6500 sh ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF11, RELEASE SOFTWARE (fc1)
srs282k3(config)#int tunnel 0
srs282k3(config-if)#ip tcp ?
compression-connections Maximum number of compressed connections
header-compression Enable TCP header compression
i have now configured on both sides
srs282k3(config-if)#ip mtu 1416
srs282k3(config-if)#tunnel path-mtu-discovery
and start the next try to test this.
regards
Klaus
Farrukh Haroon Thu, 08/14/2008 - 03:27
This command was introduced in 12.2(33)SXH I think.
Make sure you have PMTUD enabled through the firewall (particularly the packet-too-big ICMP type).
Farrukh
ksimsimon Thu, 08/14/2008 - 03:32
Hello Farrukh,
i have a standard config for the asa,s what means this packet too big ICMP Type?
do you hav a example for this ?
thx
Klaus
