CCX5.0(2) - Initial Setup of CRS
Aug 14th, 2008
When performing first node setup procedure, after filling in the Unified Configuration Page, the Systems Parameters Configuration page does not open (it appears done at the bottom but it's all white).
What could be the problem?
Best Regards,
mnathlic Thu, 08/14/2008 - 08:58
An easy one to check is to make sure that if you are using IE or Firefox you have "Use TLS 1.0" checked. Typically this will manifest when pulling parameters from Communication Manager, but give it a try.
gmcgill Thu, 08/14/2008 - 13:19
I have the same problem and tried this. It was not checked but after correcting this and restarting the setup - it did not work.
gmcgill Thu, 08/14/2008 - 13:32
Just spoke with TAC. It seems to be a known bug related to license file without "seats".
