CCX5.0(2) - Initial Setup of CRS
Aug 14th, 2008
Hi!
When performing first node setup procedure, after filling in the Unified Configuration Page, the Systems Parameters Configuration page does not open (it appears done at the bottom but it's all white).
What could be the problem?
Best Regards,
Ana
cjhunt Wed, 10/01/2008 - 02:32
I have the same problem, using CRS 5.0(2) fresh out of the box, installed the system by the book.
Did you get a solution for this problem?
I urgently would like to know what the problem was?
Thanks in advance,
Chris
abartolomeu Thu, 10/02/2008 - 06:05
Hi!
Check licenses and make sure the AXL service password is the same used in the CM.
Best Regards,
Ana
cjhunt Thu, 10/02/2008 - 06:09
Thanks for the reply.
I managed to use another customer's lcense just to prove this, based on another thread I saw. This was indeed the case. I had to go to TAC for a license in the end as the one I had was not working.
They came good and everything sprang into life.
Chris
