Guest Access over 4402 Controller
Aug 14th, 2008
i want to ask if there is a way to limit the speed on Guest access for every user
dennischolmes Thu, 08/14/2008 - 04:55
The easiest way is with a 3rd party load balancing box like a NetEqualizer. What I like about NetEq is that they give everyone on the guest access and equal amount of bandwidth and they also have a CALEA compliance module that would protect you in the event the interpretation of who is CALEA required were to change. As it stands CALEA only applies to ISPs and WISPs. Not hotspots. But we all know the feds and that is subject to change everytime the wind blows a different way. This box is very inexpensive(4000.00 or so) and does pretty much everything you'd want from a load balancing box.
Robert Rowland III Thu, 09/11/2008 - 05:53
according to documentation -
• Manage Bandwidth by Guest User Type. In addition to tailoring user portals, Version 4.2 enables administrators to customize bandwidth privileges for specific user groups. Administrators may easily restrict bandwidth to low-priority groups such as short-term consultants, for instance, while assigning higher throughput to groups requiring fast connectivity to resources such as enterprise resource planning (ERP) systems or research portals. When a guest logs into the network, the WLAN controller automatically enforces the bandwidth policies assigned to the particular guest's user group. The policies are applied on downstream traffic, helping to ensure that administrators are able to control network resources efficiently.
or you can go to the qos area, select "bronze" for instance and set the numbers as shown here
I am not sure if I understood if you wanted for individual users or a class of users [ guest/visitor ]
Robert Rowland III Thu, 09/11/2008 - 06:05
There is a problem with doing this in a hardware box as you suggest.
If the traffic is being shaped just before entering the wireless controllers it has already been placed on the wire that connects the controller upstream and now there potentially is no room for the traffic you want to get through. QOS is endpoint to endpoint problem.
It is similar to why effective dealing with denial of service attacks require cooperation of your upstream service providers - by the time you have seen it it's too late. You need your upstream link to not send the packets.
dennischolmes Thu, 09/11/2008 - 06:36
I dont think youre understanding the issue. QoS levels determine who gets priority on bandwidth but does nothing to limit a guest user to say a certain throughput thus insuring everyone on the guest network has equal access to the bandwidth. Bandwidth shaping boxes are meant to limit bandwidth consumption and thus equalize the playing field for all users on the guest access. This prohibits a music download from dropping the other users to their knees and is the only real way to both shape the traffic and enforce CALEA requirements.
Robert Rowland III Thu, 09/11/2008 - 15:10
I did understand the issue - the OP wishes to restrict guestA to x bandwidth, guestB to x bandwidth and guestC to x bandwidth.
Nothing was mentioned that all guests can't aggregately exceed a fixed bandwidth even when there may be no other traffic on the network. He doesn't tell us if he has guest vlan w/anchor controllers .... Lets try the built in tools first , huh ?
So if I follow the instructions as shown in this link .
And change the per-user Bandwidth Contracts from 0 Kb to x Kb ... it won't limit each user to approximately x Kb on that profile or whatever the OP asked ?
I didn't say the box you suggested wouldn't work - I like FOSS, I just said that the controller itself can do what the OP asked.
Right ??
Now I also understand that even though the OP did not ask about a class of users exceeding a maximum aggregate limit - which the box you mention will do also - so will QOS.
Right ?
hogant Fri, 09/12/2008 - 06:12
Interesting issue: I also ran across this.
I think your concern is the global aggregation on the WLAN.
While you can bw limit every user in the WLAN, if you have a 1000 users it might hurt you.
Two methods I use - QOS on the gust DMZ address blocks.
Also rate limiting the physical controller port for guest users on the switch.
To apply a rate limit on a Physical Lan switch port.
IP Block thru to 2MEG
Note: You must ENABLE MLS QOS on switch (not on by default)
Switch#sho mls qos
QoS is disabled
QoS ip packet dscp rewrite is enabled
Switch(config)#MLS QOS
!Build IP Match List
ip access-list extended Guest
permit ip any
!Build Class Map
class-map match-all Guest-Limit
match access-group name Guest
!Build Policy
policy-map Guest-Policy
description Guest Access 2000 kbps
class Guest-Limit
police 2000000 256000 exceed-action drop
!Apply On Interface
interface G/0/5
desc Guest-Access 20000 Kbps
service-policy input Guest-Policy
service-policy output Guest-Policy
Note: Only LAYER 3 interfaces (no switchport) support OUTbound service policy.
Error Message police command is not supported for this interface
Configuration failed!
Warning: Assigning a policy map to the output side of an interface not supported
It would be nice if there was a global WLAN bandwidth usage setting.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
