ISR E1 modules/interfaces
Aug 14th, 2008
  • Bronze, 100 points or more
What are the E1 network modules/interfaces supported by c1841?
Is there a link to for quick reference in general?
Show version on a c1841 indicates that it has 1 Channelized E1/PRI port.
What could be the corresponding module?
Is it NM-1CE1U, NM-1CE1B or something else?
Overall Rating: 4 (1 ratings)
njorosam Thu, 08/14/2008 - 07:23
Hi Give an email where i can mail u an good reference doc.
Richard Burts Thu, 08/14/2008 - 07:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ranil
This link has much good information about the 1841:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016a59b.html
and if you look in table 6 it lists the various modules (including E1s) that are supported on the 1841.
Rick
rsgamage1 Thu, 08/21/2008 - 00:54
Hi Richard,
Thanks for the link.
Can you comment on my second query as well please? Is there a way to identify the corresponding module with "sh version" or otherwise?
rsgamage1 Fri, 08/22/2008 - 04:01
OK I'll provide the answer myself.
show diag says that it has a VWIC-1MFT-E1 (Multi-Flex Trunk WAN) module.
According to table 6 this module has data only support on c1841.
