7.2(4) code for the ASA
I have just come across the following issue: Sysopt seems to be missing in the 7.2(4) code? or has this change?
7.2(3)
ciscoasa# sh run sysopt
no sysopt connection timewait
sysopt connection tcpmss 1380
sysopt connection tcpmss minimum 0
no sysopt nodnsalias inbound
no sysopt nodnsalias outbound
no sysopt radius ignore-secret
sysopt connection permit-vpn
7.2(4)
ciscoasa# <no output>
ciscoasa(config)# sysopt connection ?
configure mode commands/options:
permit-vpn Exempt VPN traffic from access check
tcpmss Set maximum TCP MSS limit, specify keyword minimum to configure
minimum TCP MSS limit. Defaults for maximum and minimum limits
are 1380 and 0 bytes respectively
timewait TCP connection undergoes TIMEWAIT state
ciscoasa(config)# sysopt connection permit-vpn
ciscoasa(config)# sh run sysopt
ciscoasa(config)# <no output>
Overall Rating: 5 (1 ratings)
Farrukh Haroon Thu, 08/14/2008 - 11:26
  • Red, 2250 points or more
Seems to be a bug, they fixed an older bug in 7.2(4) as per the Bug Tooklit:
CSCsi18713
Symptom:
Commands that are system defaults do not show up in the
typical "show running-config" output. The purpose of the "show running-config all" command
is to allow all configured commands both default and non-default to be viewed in one output.
For PIX/ASA, the output of the command "show running-config all" should
include the the configured sysopt commands such as
"sysopt connection tcpmss 1380" which at present, it does not.
ciscoasa# sh run all | incl sys
ciscoasa# sh run all | incl sysopt
ciscoasa#
Conditions:
Some "sysopt" commands are on as system defaults and do not show in the running configuration output. However, the "show running-config all" output is supposed to show
all commands in the running configuration including the defaults like some sysopt commands. This issue is purely cosmetic and does not affect the operation of the PIX/ASA.
Or perhaps you can only see the non-default commands using show run sysopt now (after the fix), and for default commands you have to do:
show run all | inc sysopt
You can check this by configuring a non-default config for one of the sysopt commands.
Farrukh
slug420 Thu, 08/14/2008 - 13:27
the command exists
it is (no) sysopt connection permit-vpn
it only shows up in a show run/show conf when it is disabled and it is enabled by default
