backing up PIX 6.3.1 over outside interface
Aug 14th, 2008
I have a PIX 525 running 6.3(1). There firewall is within my internal network and protects a server segment. I don't have a TFTP server on the "inside" side of the PIX. So the TFTP transfer has to go out the "oustide" interface to my workstation (10.10.10.50) . This however is not working due to what I believe is a security limitation. Does anyone know how I can make this work?
inside interface: 192.168.0.1
outside interface: 10.10.10.1 (aka interface 4)
TFP server: 10.10.10.50
FW# write net 10.10.10.50:FW
Building configuration...
TFTP write 'FW' at 10.10.10.50 on interface 4
Timed out attempting to connect
[FAILED]
FW#
vman1976nj Thu, 08/14/2008 - 07:47
Nevermind, I did a little digging and found the answer via google.
To use TFTP going over a low secuirty (0) interface you need to define the server in your config.
In my example
conf t
tftp-server outside 10.10.10.50 fw
then from enable prompt:
write net:
