Yes -
but not directly from the FWSM. the FWSM simply becomes part of the switch, using its trunks, backplane, and forwarding logic to make a firewall ON THE SWITCH...
so to do this, simply assign the vlans to the FWSM on the switch in question with the switch fwsm commands
firewall module 4 vlan-group 2
firewall vlan-group 2 333,352
then configure a trunk to the other switch such as
int g1/48
switchport
switchport mode trunk
switchport trunk native vlan 999
switchport trunk allowed vlan 333,352
You now have the functionality you require.
just make sure you create the vlans..
vlan 333
vlan 352
etc.
The receiving switch can do what ever it wants with the tagged frames, put them on to router access ports, server access ports, etc.
-Joe
oops i read trunk and you said etherchannel.
same thing;
just tie two or more dedicated ports for an etherchannel trunk so like i had before but,
int range g1/47-48
channel-group 1 mode desirable
int port-channel1
switchport
switchport trunk en do
switchport trunk mode des
-Joe
