how to delete CTL of ip phone
Aug 14th, 2008
Hello I need to know how to delete CTl from ip phone, i have problem that when I make the following thing Device - > Phone - > X Phone -> Certificate Operation -> Delete and I make Device Security Mode a Non Secure in device phone, the ip phone do not can register in other Callmanager why still it have a same relationship of trust.
willibr0 Thu, 08/14/2008 - 07:50
Reset the phone to defaults and it should delete the certificate. Do this by unplugging the phone power and when you plug it back in hold down the # button until the line buttons flash amber. After that hit 123456789*0# and it should reset to defaults and register to the new call manager.
Bryan
santiago_figuer... Sat, 08/16/2008 - 09:02
hello thanks for your reply, do you knows if exist any way to apply it to 4000 ip phone?. it is very low, I need anything more quick to do it.
DWAM_2 Mon, 08/18/2008 - 11:01
I have got the same behaviour but for 600 Ip phones.
We have asked semi-officially to Cisco but it seems that you have to pass physically on all phones.
Regards.
christoph.hable Mon, 10/13/2008 - 04:39
Hy!
are there any news to this issue? We plan to upgrade from CCM 4.1.3 to UCM 6.1(2). ~1200 phones are concerned.
Does it work with BAT to delete CAPF and change profile to non-secure or do we have to migrate the existing CAPF data?
Configured CAPF Infos:
By Null String and 1024Bit.
With UCM6 we want to use existing Certificate (LSC).
Christoph
