tdrais Thu, 08/14/2008 - 18:45
  • Blue, 1500 points or more
Just had one of these happen recently. Never did find out exactly what reset means.
I still suspect the one of the vendor changed to frammed from unframmed for a period of time but no proof. 3 different telco involved.
We put a hard loop plug toward the router to verify the cabling in the building. It came up/up looped like normal and the reset never came back after we reattached the circuit a couple hours later.
Not that I would say that a hard loop plug will fix your problem it is easy to try.
When I tried to look this up all i found about reset was related to PRI cards.
