Need the details for this command.
Aug 14th, 2008
I have questions regarding to this command:
show interfaces status mod 2;
What "mod" means? Module 2 or Mode 2?
If it means Module, how can I find the correct module the ports reside?
Thanks for help
Overall Rating: 5 (1 ratings)
garytayl Thu, 08/14/2008 - 08:32
  • Silver, 250 points or more
Indeed it means module.
In regards to the modules/ports question, if you use only show interface status, you will get a list of ports so for example for Gig1/1, the first number will be the module and the second for the port.
Also, show module all will let you know the modules you have along with its correspondent number.
