Re; CUCM 6.0.1 Attendant console
m-laing
Hi have configured the Cisco Unified CM attendant console Pilot point and it will not register. registration is coming up as unknown, can you assist?
5 Replies 5
Jaime Valencia
have you gone thru the whole configuration?? members added to the hunt group? devices and PP associated??
try resetting the PP
java
if this helps, please rate
java
I added the pilot point, added hunt group numbers, created the AC user
what is pp?
pilot point
have you associated the devices and pp??
java
java
m-laing
the association of the pp with device was done
ariel.vera
I THINK THAT YOU MUST ADD USER GROUP TO THE PILOT POINT IN THE PERMISSION INFORMATION FIELD
Standard CTI allow call park monitoring
Standard CTI ALLOW CONTROL ALL DEVICES
STANDARD CTI ENABLED
