DS3 / HSRP Questions
Aug 14th, 2008
Hello all,
I'm currently working at a site with a T1 connection between their main HQ, and remote sites. We are upgrading the existing T1, to a DS3 line, and I've run into a few questions.
I've never turned up a DS3 before, so I'm wondering what types of things i need to know, like for a T1, I'd need to know the type of framing used, and the linecoding as well.
What would I need to know from our carrier for the DS3 line?
Also, we're thinking just to be safe, to keep our existing T1 as a backup line until we make sure the circut is stable. Is there an easy way to configure HSRP on a 3845 to failover to our existing 2621XM T1 circuit?
Thanks, and i'm sure there will be more questions to follow.
Jonathan Kloza
Collin Clark Thu, 08/14/2008 - 09:48
  • Purple, 4500 points or more
Here's a working example of a interface (DS3).
interface Serial1/0
description DS-3
bandwidth 44210
ip address a.b.c.d 255.255.255.252
ip route-cache flow
dsu bandwidth 44210
framing c-bit
cablelength 250
serial restart-delay 0
The most important info to get from the carrier is the dsu bandwidth, it must match.
Hope that helps.
Giuseppe Larosa Thu, 08/14/2008 - 11:23
  • Hall of Fame,
    Founding Member
Hello Jonathan,
the DS3 config info has been given in the previous post.
about HSRP: on C3845 you need to track the DS3 interface in the HSRP group so that if DS3 fails the HSRP master becomes the C2621XM with the T1 exit link.
standby 11 track interface serx/y
standby 11 pri 105
standby 11 preempt
you need to configure premption also on the C2621XM and the VIP address on both
Hope to help
Giuseppe
