SQL statement to convert Epoch time to Human Readable
dolah
I am looking for the SQL statement that can be used in a query (Query Analyzer) against the CDR database to convert the format from Epoch to MM/DD/YY 00:00:00.
I've googled "Unity Epoch time" (as mentioned on one forum posting) and even asked TAC, but no luck.
Any assistance would be greatly appreciated.
smallpygmy
The statement you are looking for is:
DATEADD(s, dateTimeOrigination, '19700101')
i.e. select DATEADD(s, dateTimeOrigination, '19700101'), duration, callingPartyNumber, originalCalledPartyNumber from callDetailRecord
As a bonus, you can also use
CONVERT(varchar(6),duration/3600)+':'+RIGHT('0'+CONVERT(varchar(2),(duration % 3600)/60),2)+':'+RIGHT('0'+CONVERT(varchar(2),duration%60),2)
to convert the duration from seconds to H:M:S
smallpygmy
Thank you, I'll try this today.
Thank you, this resolved my issue.
I used the DATEADD line and was able to print a readable report.
Debbie
