Unity 4.X to 5.X
jmecklenburg
Level 2
Level 2
Hi..
I need migrate the Cisco Unity 4.X to 5.X (the Unity 5.X is a new server).
I backup the server 4.X whit a DiRT but when I try to restore the information in a 5.X the process down because is no compatible version.
How to can used the backup files to install in Unity 5.0
fixie rider
8 Replies 8
ranpierce
Level 6
Level 6
DiRT is not a upgrade tool, you could install 4.x on the new server and then upgrade because you have to restore with the exact same version that you backed up with.
http://www.ciscounitytools.com/App_DisasterRecoveryTools.htm
A lot of people are using COBRAS to upgrade with. It is not TAC supported yet though.
http://www.ciscounitytools.com/App_COBRAS.htm
I would install 5.0 on the new server and use GSM to move the subscribers.
http://www.ciscounitytools.com/App_GSM4x.htm
Which ever tool you use read all the help files and watch the videos.
Randy
Please rate if this helps.
Can i use COBRAS whit remote terminal?
fixie rider
that I am not sure of. Tommer you there?
Tommer uses COBRAS a lot, I am checking the help files right now.
Randy
It will work over RDP!!!!!!
Randy
I have over way to make the upgrade?
fixie rider
not sure what you mean.
Other way to export database to replicate in Unity 5.X.
fixie rider
there are 3 ways I stated in my first post.
DiRT, COBRAS, and GSM
those are your only choices unless you want to do a fresh install.
Randy and hope this helps
