How to Shut Off WAAS?
Answered Question
Aug 14th, 2008
I would like to be able to test the difference for when WAAS is Optimizing and when it is not. I have 2 inline WAE's. I am specifically interested in measuring the impact of WAAS on RDP between the 2 sites with the WAE's. So, the first thing I did was de-Activate both WAE's. When I use the GUI to the Central Manager, it indicates that nothing is being reported by the Connection Statistics. However, when I connect to the WAE's themselves and "show tfo conn summ", I see that the WAE's are still optimizing traffic between them. Next, I tried going to the Device Group Policy Definitions and changing the Remote-Anything policy to Passthru, but the connections are still being optimized. Finally, I tried using the GUI to reload the WAE's, but that did not actually Reload them :-(
Any ideas on how to turn WAAS optimization on and off for WAE's in inline mode? Thanks!
Correct Answer by ropethic about 8 years 9 months ago
Under the inline interface configuration:
no inline vlan all
Overall Rating: 5 (2 ratings)
Correct Answer
ropethic Thu, 08/14/2008 - 12:59
  • Silver, 250 points or more
no inline vlan all
bbeal-spang Fri, 08/15/2008 - 04:47
Thanks! That did it. Can I ask what the point of the No Activate button in the CM GUI, besides shutting off reporting, but not shutting off optimization?
ropethic Fri, 08/15/2008 - 06:45
Good point. Activating the WAE with central manager only always for reporting and being able to send configuration changes to the WAEs as opposed to using CLI.
Understand, WAEs auto-discover each other when a TCP SYN packet is intercepted and optimization occurs between the WAEs. CMS registration allows for optimization reporting and Device / Device Group configuration.
Let me know if you need anything further
Rob
ropethic Thu, 08/14/2008 - 14:27
or
shutdown inline interface - Inline adapter has a mechanical fail to wire, so shutting down will bypass WAE
I recommend the no inline vlan all command on the inline interface configuration
