Help with simple scripting needed for CCX 5.0(2)
Answered Question
Aug 14th, 2008
Can anyone please provide me an example (or steps) of simple scrip using CRS Script editor for CCX 5.0(2)for following simple scenario? (I've been going over Help Guide but got very confused.
Our scenario:
When call comes in, promt is played:"Press 1 for Sales, Press 2 for Service, Press 3 for Payments, Press 0 for an Operator". When caller presses a selection call gets forwarded to specified Queue and appropriate skilled agent gets a ring tone.
Thank you in advance.
Gundars
Correct Answer by Clifford McGlamry about 8 years 9 months ago
Chad's script is correct, but it also assumes you have the Queues set up correctly on the server, and agents assigned to them.
Also, with the setup you have, the caller will hear silence for 30 seconds at a time while holding in queue. You could put them on hold and let CCM stream hold music to them (it's a technique thing....you don't have to do it).
Correct Answer by Chad Stachowicz about 8 years 9 months ago
gundar,
Under Tools-> validate you can hit that and it produces you error's. In your case you had all your's queue's having the label0. Every label needs to be unique in a UCCX world. I have fixed it and reattached it, give that a shot.
HTH, please rate the post if you find it helpful
Chad
Overall Rating: 5 (3 ratings)
Chad Stachowicz Thu, 08/14/2008 - 18:00
  • Silver, 250 points or more
hey gundar it sounds like you a very new to scripting but its all good. In C:\Program Files\wfaavid\scripts\system\default.. or something to that effect on the UCCX Server there is some example scripts. The icd.aef script shoul be a decent example of queueing.
However in a quick outline of a script you want
Accept contact
Menu <--Under Menu make your 3 things
Under that you will need to do the associated 'Select Resources' steps pointed to the CSQ's that you created with your agents. From there under Select resource its connected or Queued. Just lookp a prompt and Call Hold, Delay, Call Unhold to make MoH play for MoH while in Queue.
Thats about it!!
HTH, please rate useful posts
Chad
Accept contact
Thats about it!!
Chad
Gundars Dubults Fri, 08/15/2008 - 05:42
Hi Chad ! Thanks a lot for your quick response. It is a simple script, I have tried your suggestions and many other options but still cannot make it work. I've attached my script, could you please take a quick look over it?
Correct Answer
Chad Stachowicz Fri, 08/15/2008 - 07:05
gundar,
Chad
Correct Answer
Clifford McGlamry Fri, 08/15/2008 - 13:26
  • Community Spotlight Award,
    Best Publication, November 2015
Gundars Dubults Sun, 08/17/2008 - 23:18
Thank you for your detailed explanation and suggestions! Now I will work on it.
Gundars Dubults Sun, 08/17/2008 - 23:14
Thans a lot Chad for correcting this script. Now it works!
Appreciate your quick and useful help!
Gundars
Accept contact
Thats about it!!
Chad
