08-14-2008 01:30 PM - edited 03-06-2019 12:48 AM
I am trying to include trunk ports into an etherchannel with a QoS input and output policy. Every attempt to put it into the channel-group fails because the physical interface has a service-policy attached to it.
I've tried to put the input/output service policies on the Port Channel virtual interface, but it only allows me to put the input policy on, not an output policy.
If I have any service-policy defined on the physical interfaces, it will not join the channel-group.
The interfaces are Layer 2 trunk ports to a 6509 and the Etherchannel is Layer 2 only.
With QoS enabled on the switch, will all the QoS markings be trusted by default over these trunks and therefore don't need to have the policies defined?
Its a Catalyst 4506E with Sup 6E.
interface Port-channel1
description L2 Etherchannel for trunk to 6509
switchport
switchport trunk native vlan 999
switchport mode trunk
interface GigabitEthernet3/47
description L2 trunk to 6509
speed 1000
duplex full
channel-group 1 mode desirable
interface GigabitEthernet5/47
speed 1000
duplex full
08-14-2008 01:50 PM
Im no QoS guru, but I can tell you that you should identify your traffic, mark it, and then apply a policy to it as close to the origin as possible.
Then, at each successive hop (layer 2 or L3), you will want to use the "mls qos trust cos" command (switched ports) or the "mls qos trust dscp | ip precedence" command (routed ports) to extend the trust boundary. By default, a port does not trust the CoS/QoS markings of the packet it receives.
As far as why you cant apply a policy in the outbound direction or why you cant apply it t the port channel, I will have to investigate.
Qute frankly I have always wondered why certain switch platforms do not allow you to apply a QoS policy in the outbound direction....seems strange.
Hope I was of some help.
[EDIT] To the QoS expert who will answer the call for help, if I am incorrect about anything, please let me know. Thanks. [EDIT]
Victor
