Issue initiating Tunnel from IPSEC tunnel from 1841 router to ASA
Aug 14th, 2008
I have configured a IPSEC site to site tunnel between Cisco 1841 Router and ASA 5510. (the configuration is the same as it is in the example in the cisco site except for the route-map utilisation).
I am experiencing a typical problem while initiating a tunnel from the lan behind Cisco 1841. Tunnel does not come up but when I initiate traffic from the lan behind ASA the tunnel comes up and normal traffic passes through.
Can anyone please help me resolve this issue.
K.V.Krisshna
Marwan ALshawi Thu, 08/14/2008 - 19:52
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
can post the router config
singhsaju Mon, 08/18/2008 - 13:13
  • Silver, 250 points or more
If you use Route map , does it resolve your issue?
Farrukh Haroon Mon, 08/18/2008 - 21:54
  • Red, 2250 points or more
Can you post debugs for Phase 1?
Farrukh
AGINetworkGroup Tue, 08/19/2008 - 09:21
Hi Saju,
Thank you for the reply.
I have tried using the Route-map even but it did not work out.
K.V.Krisshna
singhsaju Tue, 08/19/2008 - 10:29
Hello ,
Your config looks ok to me except that you are not using route-map , but you have checked it gives you same result.
Can you post config from ASA side?
Also you can refer follwoing link :
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805e8c80.shtml
If your configs are ok then you can consider opening cisco tac case and check if the IOS is not hitting any bugs etc.
Saju
AGINetworkGroup Thu, 08/21/2008 - 15:56
Thank you Saju,
The config seems to be ok with the eample config above. I guess i need to open a tac case with Cisco for further on this.
K.V.Krisshna
