dial-peer cor-list problem
Aug 14th, 2008
I want to set up a dial-peer cor list to prevent my directly attached FXS ports from dialling internationally, and to stop my SRST devices calling internationally. I have set up some cor lists etc, but find that during normal running, calls from my IP Tel phones are coming in on dial peer 0.
According to my thinking, they should be coming in on dial-peer 200, based on the destination pattern:
dial-peer voice 200 voip
corlist incoming UNRESTRICTED
corlist outgoing CCM-AND-SRST-ONLY
description 1ST PREFERENCE OUTBOUND PEER TO CCM SERVER (1ST SUBSCRIBER)
destination-pattern 2...
progress_ind setup enable 3
modem passthrough nse codec g711alaw
voice-class codec 1
voice-class h323 1
session target ipv4:172.19.70.11
dtmf-relay h245-signal h245-alphanumeric
no vad
any ideas?
Marwan ALshawi Thu, 08/14/2008 - 18:53
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
lets say u have the folowing example
dial-peer cor custom
name int
name local
dial-peer cor list int
member int
dial-peer cor list local
member local
dial-peer cor list LocalCalls
member local
dial-peer cor list International
member int
now this is for internation calls
dial-peer voice 9011 pots
corlist outgoing int
destination-pattern 9011T
port 1/0:23
prefix 011
and this for local calls
dial-peer voice 7 pots
corlist outgoing local
destination-pattern 9[2-9]......
port 1/0:23
forward-digits 7
just goo to the fxs port then apply
cor incoming LocalCalls
this case he has only access to the local calls dia-peer based on the above example
just follow the idea and if u want any more details juist post it here
good luck
please if helpful rate
