Traffic from ASA to IPS
Aug 14th, 2008
Hello Everyone,
I have configured an ASA5510 to send all traffic to IPS like bellow as cisco doc described.
access-list IPS extended permit ip any any
class-map my-ips-class
match access-list IPS
policy-map my-ips-policy
class my-ips-class
ips inline fail-close
service-policy my-ips-policy global
And all incommeing traffic from outside should go to IPS. How to make sure that traffic is going to IPS.
If i give command like this
sh service-policy global
its showing below:
Global policy:
Service-policy: my-ips-policy
Class-map: my-ips-class
IPS: card status Up, mode inline fail-close
packet input 12119, packet output 12119, drop 0, reset-drop 0
Then I go to ips and enable a signature definition number 2004 to denay ICMP echo request. In actions i choosed deny packet inline. but still i can ping from outside to inside.
Please advise sir what to do.
Overall Rating: 5 (1 ratings)
antonyabraham Fri, 08/15/2008 - 06:50
Did you check in the IDM if the signature 2004 is firing? If it is firing, make sure the "Deny packet" option is set correctly.
Trust your virtual sensor vs0 config is completed and the interface Gig0/1 is added to the vs0.
You could also use the "packet dispaly interface Gig 0/1 expression (tcpdump expressions)" on the IPS CLI to see if the sensor is indeed seeing the Echo traffic.
gtuhindhaka Sat, 08/16/2008 - 00:20
Thank you very much sir. Its now working. I didn't add interface Gig0/1 to vs0.
Thanks you.
