VPN connects, I can see folders but not files
Aug 14th, 2008
I installed the VPN client on 3 laptops. Two are fine but the third connects and sees the server shared folders but not the files. I have tried using different logon credentials that work on the other laptops with the same result. So I think it is specific to the computer and not user or a rights issue.
Marwan ALshawi Thu, 08/14/2008 - 20:56
as long as he gets connected and also can reach the server
then the vpn working fine
unevenload Fri, 08/15/2008 - 07:02
Respectfully, if I am getting a icon that says the VPN is connected but I can't see the files I have a problem somewhere. When connected locally I have access to the files and connecting via the VPN on other computers with the same credentials I have access.
unevenload Sun, 08/17/2008 - 19:23
No. Request times out. When connected I can see the folders using windows explorer, just not the files. When running IPconfig I noticed that I am not getting a default gateway on the VPN connection. I am getting the correct IP and subnet.
Marwan ALshawi Sun, 08/17/2008 - 19:38
r u using router or firewall?
do u have nat configured
if yes,
it sounds u missed the nat exmption
unevenload Sun, 08/17/2008 - 20:13
We are using a ASA 5505. This is new to me. Do I set the NAT exemption on the local client? The VPN works on my other laptops so I assumed the ASA box was configured correctly. I contracted out the initial setup.
Marwan ALshawi Sun, 08/17/2008 - 20:18
if the others works fine dont change the config
just make sure if it is not from the computer u use
so try any other computer and try to connect
and let me know
good luck :)
