Incoming Calls
Aug 14th, 2008
Hi Guys,
I have a problem on a new setup with incoming calls not ringing through to the phone.My dial peers are being matched and i`m using translation patterns to convert from 6-5 digits.Gateway is H323.So is there a way of checking where the breakdown is occuring on ccm 6.0 ?
Also does it matter if the phones and the ccm are on different vlans.The phones are registered with the ccm...thanks!
Overall Rating: 5 (1 ratings)
Marwan ALshawi Thu, 08/14/2008 - 21:40
if they are in deffrent vlans and can communicat its ok
and about the translation pattren
if u only makthe 6 digits or 7 to 5
u can avoid this and let the H323 forward the whole number to the CUCM
and on the CUCM on the gateway seetings there is option called significant digits
chose 4, 5 what ever number u want to be forwarded
for example if u use only last for digit on the internal ip phon
chose 4
and make sure u forward the hole number in this case
Steellllllllll0 Fri, 08/15/2008 - 00:32
Hi Guys,
Part of the problem is also when i dial in i get two calls showing up on the debug q931 from my no at the same time :
Calling Party Number i = 0x2183, '7895606931'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '260'
Called Party Number i = 0x81, '579260'
I have tried matching both patterns on the dial peers as well as the translation patterns.
Steellllllllll0 Fri, 08/15/2008 - 01:42
Here is a scaled down version of the voice config :
aaa session-id common
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
ip cef
isdn switch-type primary-net5
voice-card 0
no dspfarm
dsp services dspfarm
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice class codec 1000
codec preference 1 g711alaw
voice class h323 1
h225 timeout tcp establish 2
call start fast
voice translation-rule 1
rule 1 /^2/ /792/
voice translation-profile Incoming
translate calling 1
username
username
controller E1 0/1/0
pri-group timeslots 1-18
controller E1 0/1/1
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.200
encapsulation dot1Q 200
ip address 10.X.X.X 255.255.255.192
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.X.X.X
interface GigabitEthernet0/0.500
encapsulation dot1Q 500
ip address 10.Y.Y.Y 255.255.255.192
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Vlan1
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0.500
control-plane
voice-port 0/1/0:15
cptone GB
dial-peer voice 50 voip
description **h323 incoming calls**
destination-pattern 579...
progress_ind setup enable 3
voice-class h323 1
session target ipv4:10.c.c.m
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate disable
no vad
dial-peer voice 40 pots
description **Incoming Pstn Calls**
destination-pattern 5792..
direct-inward-dial
port 0/1/0:15
dial-peer voice 51 voip
translation-profile incoming Incoming
destination-pattern 2..
voice-class h323 1
session target ipv4:10.3.110.140
fax rate disable
no vad
dial-peer voice 41 pots
description **Incoming calls**
direct-inward-dial
port 0/1/0:15
Thanks!!
Marwan ALshawi Fri, 08/15/2008 - 02:09
incoming called-number .
direct-inward-dial
port 0/1/0:15
forward digit all
after each pots dial peer u need eaither forward digit all
or forward digit [number of digits]
and ur thranslation profile is translating the calling number not called
is that what u eant?
translate calling 1
can u just send what u want to be forward [numbers to ccm] and send to pstn and what numbers u recieve and wanna send exactly to fix those dialperrs
thanks u
Steellllllllll0 Fri, 08/15/2008 - 02:24
There are no incoming calls at all coming through to my DN`s i have checked the class of control/gateways etc translation patterns.
As in my previous posting if i dial one of my numbers from my mobile i get two calls coming through on the isdn at the same time both with my cli but presenting different amounts of digits.I am just thinking this is part of the problem.If i debug the dial peers they are being matched tho:
Aug 15 08:48:50: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2183, '7589526412'
Plan:ISDN, Type:Unknown
Aug 15 08:48:50: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2
0x1, Calling num 7589526412
Aug 15 08:48:50: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0
0x1, Called num 260
Aug 15 08:48:50: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8001
Aug 15 08:48:50: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A0
Sending Complete
Standard = CCITT
Channel ID i = 0xA98392
Exclusive, Channel 18
Aug 15 08:48:50: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80A0
Aug 15 08:48:50: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x80A0
Cause i = 0x8A96 - Number changed
Progress Ind i = 0x8488 - In-band info or appropriate now available
Aug 15 08:48:50: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8001
Aug 15 08:48:50: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x80A0
I have checked everything i can possibly think of and cannot find anything this is the only thing which is not right.
btmulgrew Fri, 08/15/2008 - 02:56
Hi - I think your inbound and outbound calls are being matched by your pots dial peer.
As mentioned in previous post change your translation profile to called. Also remove translation profile from voip dial peer and apply to voice port as incoming.
Marwan ALshawi Fri, 08/15/2008 - 03:05
no voice translation-profile Incoming
translate called 1
voice-class h323 1
fax rate disable
no vad
incoming called-number 5792..
direct-inward-dial
port 0/1/0:15
forward digit all
description **outgoing calls**
translation-profile outgoing Incoming
direct-inward-dial
port 0/1/0:15
forward digit all
try to keep only the above dial peers with the change i have made to u
and see it
Steellllllllll0 Fri, 08/15/2008 - 03:48
Thats exactly as i have it at the moment but still calls are ringing but not on the handset.
Is there a way on ccm 6.0 to actually see if the calls are reaching the ccm ??
Marwan ALshawi Fri, 08/15/2008 - 03:59
first how many digits r u using in ccm?
and how many digit u send to ccm?
have u checked the option significante digits on the gateway settings?
u have to chose how many digit u want ur ccm take from the gateway
let me know about these digits
if u send me ur dial paln will give u the exact config if u want
send want is the numbers u use in ur ccm
what numbers u recieve and want to send to and from the pstn
Steellllllllll0 Fri, 08/15/2008 - 04:44
The carrier is presenting 6 digits (579XXX) and my extension numbers are the last five digits (79XXX).Dial peers are setup exactly as u outlined previously.I have translation pattern translating the 6 digits to 5digits and Sig Digits on the gateway set to 6.Even with this set to 5 and no translation pattern calls still do not ring through.I dont have anything listed under my dial plan installer on ccm....is this why ???
Marwan ALshawi Fri, 08/15/2008 - 05:29
first save all the config u have to external file
then remove the translation profile u have and all the dial peers and use the following seetings:
rule 1 /5\(79...\)/ /\1/
voice trnaslation-profile progile1
translate called 1
dial-peer voice 9 pots
description "incoming-outgoing pots"
translation-profile incoming profile1
incoming called-number 579...
destination-pattren 579...
direct-inward-dail
port 0/1/0:15
forward-digit all
dial-peer voice 99 voip
destination-pattren 79...
session target ipv4:[ur ccm ip]
on the CCM make the significant digit either 5 or all because we have used translation on the gateway
also make sure u have registered phones with numbers in the range of 79000 - 7999
and also make sure u have seted up the CSS and partitions corectly on the phones and the gateway setting on the CCM
Steellllllllll0 Fri, 08/15/2008 - 06:16
voice translation-profile incoming
translate called 1
destination-pattern 79...
voice-class h323 1
fax rate disable
no vad
translation-profile incoming incoming
direct-inward-dial
port 0/1/0:15
forward-digits all
In CCm,gateway css set to Unrestricted and sig digits set to all(tried 5)
DN & phone in same css as gateway
Still it will not work !!
Marwan ALshawi Fri, 08/15/2008 - 18:38
phone not inmportant to be in the same CSS as the gateway
but the should be in a partition included in the gateway CSS
this is for incoming calls
the revers of the idea for outgoing calls
make sure that the gateway CSS includ the phones partetion
good luck
a.gooding Fri, 08/15/2008 - 22:10
just a small input
id do the following csim start and the extension number - at least if it works then it is going from the rtr to the ccm to the phone basically.
then debug voice ccapi inout and see whats going on there with the DP and what digits are coming out.
