privilege level 0 commands
Answered Question
Aug 14th, 2008
Have all IOS commands been assigned either priv 1 or 15 by default since time immemorial? Or at some point in the past were some commands assigned priv level 0 by default?
Thanks much
Correct Answer by Jagdeep Gambhir about 8 years 7 months ago
Not sure if I understand your question. Me be this link with help you,
privilege level 0 - Includes the disable, enable, exit, help, and logout commands.
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a00800949d5.shtml
~JG
Overall Rating: 5 (1 ratings)
jdevoll Fri, 08/15/2008 - 06:50
You answered it. I found a passage in a Cisco Press book that stated that all commands are either priv level 1 or 15 by default, which conflicted with my understanding. So perhaps the book doesn't consider disable, enable exit, help and logout as "commands", or it's a mis-statement. Cisco press is pretty bad about making incorrect statements.
