IVR applications on CUCM
egua5261
Hi There,
I'm interested to know if there is a feature in CUCM 6.X (may be an IVR application) it can be used to collect digits, entered by a caller via the phohe keypad, the passsing this to a different system in a text file for instance?
Any help is appreciated.
Esteban
Jaime Valencia
no, CUCM is a call agent, not an IVR. you need extra SW to perform that (UCCX, UCCE, CVP)
java
if this helps, please rate
java
amritesh.anand
You can use TCL scripts on the Voice Gateway for basic IVR Functionality with CUCM
http://www.cisco.com/en/US/docs/ios-xml/ios/ios_tcl/configuration/12-4t/nm-script-tcl.html
Amritesh Anand
Pleaes rate if found helpful
