static route on cisco pix 515e
Aug 15th, 2008
Hi all. I have a cisco pix 515e where the internal ip is and dmz ip is I have a router which connects subnet with the ip and connects to subnet. There is a server on my dmz with the ip 192.168.2.x that i want it to connect to another server in subnet. Hence i would like to add a static route on my pix as below.
I understand that the ciscopix 515e with version 6.x cannot do hairpinning which is routing using the same interface. Hence for this scenario(which is not hairpinning) will the server in dmz be able to access the server 192.168.3.x after i add the above static route? Thks in advance.
Marwan ALshawi Fri, 08/15/2008 - 01:42
route inside
and u need a route on the router aswel
ip route 192.168.254
and u need the following acl on the pix
access-list 100 permit ip
access-group 100 ininterface dmz
good luck
please, if helpful rate
donnie Fri, 08/15/2008 - 06:50
Hi Marwanshawi,
Thks for the advise. I forgot abt the return path, thk u for highlighting it to me. Basically i post this question because my boss says adding static routes to firewall is not possible. However i feel that as long as its not hairpinning, static routes added to the firewall would work.
