08-15-2008 01:03 AM - edited 03-14-2019 02:43 AM
Hi, I am trying to redirect calls to a established meet-me conference call. But after it had been redirected, the call just drop. I have no problem redirecting the call to my mobile and dialling into the meet-me conference the usual way. Is it possible to do this?
Donny
Solved! Go to Solution.
08-25-2008 08:03 PM
This looks like a CSS/Parition issue, ensure the following:
- the CSS applied to the incoming GW has the Partition of the cti ports listed
- the CSS applied to the CTI ports has the partition of the MeetMe listed
Chris
08-17-2008 06:50 PM
is there anyone who have tried this before?
08-18-2008 05:59 AM
You should be able to do this, is the Partition applied to the MeetMe numbers listed in the originating CSS, i.e. GW CSS?
Are you using the correct codec?
Have you looked at the MIVR logs for clues?
Chris
08-21-2008 07:49 PM
Thanks Chris, I have looked into the MIVR log and found the call was dropped.
Connection to dest=2350 for outbound call failed, callctl cause:103, reason=RESOURCE_INVALID
3953: Aug 22 11:35:09.340 GMT+800 %MIVR-SS_TEL-7-UNK:Call.rejecting(RESOURCE_INVALID) JTAPICallContact[id=2,implId=9016/1,state=STATE_INITIATED_IDX,inbound=false,App name=ExtVRec,task=26000000002,session=20000000003,seq num=0,cn=null,dn=null,cgn=null,ani=null,dnis=null,clid=null,atype=OUTBOUND,lrd=null,ocn=null,route=RP[num=0000],TP=226]
3954: Aug 22 11:35:09.340 GMT+800 %MIVR-SS_TEL-7-UNK:CallID:2 MediaId:9016/1, dropping the call, ciscoCall state is ACTIVE
I do not understand what is the reason that it was dropped. Anyone can help me? Thanks.
08-25-2008 08:03 PM
Chris
