urgent help in pbr
Aug 15th, 2008
Dear all
i have 2 offices, from office A i have 2 point to point leased lines(128kbps each)
connecting to office B.
office A ------------------- Office B
192.168.1.0/24 ------------------ 192.168.3.0/24
i have not bundled the 2 serial lines i had put 2 routing entries in office A router
ip route 192.168.3.0 255.255.255.0 Serial0/0/0
ip route 192.168.3.0 255.255.255.0 Serial0/0/1
from office B router also i have the proper routing entries and it is working fine.
now my requirement is i have got an internet leased line and i've 6 public ip addresses as well, from office A i need to publish one server i tried configuring
policy based routing on the same router but it is not working can anybody help me in this issue.
i will post the configuration file please have a look into it.i will rate all the suggestions
thanks & regards
Binoy
Giuseppe Larosa Fri, 08/15/2008 - 08:25
Hello Binoy,
in your scenario I don't think you need PBR.
just use extended ACL to permit only private-to-private or public to public traffic.
In fact,
when going to private you will go to siteB
when going to the internet you will go via the interface that provides the default-route
use ACLs to avoid sending packets with private RFC 1918 addresses to the internet
access-list 121 deny ip 192.168.0.0 0.0.255.255 any
access-list 121 permit ip 85.154.246.144 0.0.0.7 any
access-list 121 permit ip 85.154.246.180 0.0.0.3 any
int ser0/10
ip access-group 121 out
Hope to help
Giuseppe
