AP c1252 config assistance
Aug 15th, 2008
  • Bronze, 100 points or more
First time playing with c1252 and I got some issues.
1.I enabled all the high throughput rates, set WMM policy to 'Allowed' under WLAN and tested with open authenticated WLAN under 2.4g. But I only got 65M on both Linksys 300N card and a Macbook. What could be the problem?
2. Under "Higher Throughput" MCS settings, do I need to set all the rates to 'supported'? Any benefits to support rates lower than 58Mbps here?
3. We use c3750E switch and I can see both A and B/G radios are up for the AP. But the AP only draw 15.4 watts from the switchports, not 18.5 watts as expected. Is it the problem?
Thanks!
Zhenning
Overall Rating: 3 (1 ratings)
zhenningx Fri, 08/15/2008 - 07:51
I figured it out. The lower data rate I got is caused by the AP not drawing full power from the switch.
First I need to upgrade my switch to 12.2(44)SE to support Enhanced PoE.
Then the AP still draws 15.4 watts with automatic power negotiation. I have to use follwoing commands under swtich port level:
power inline static
power inline port max 20000
Then the AP draws 20watts and I got 130Mbps.
So everyone has to manually set power maximum 20watts for 1252 APs? Anyone has it working using automatic?
And I don't see it is documented anywhere in CCO!
Zhenning
zhenningx Fri, 08/15/2008 - 08:32
Sorry after several minutes, the speed drops down to 65Mbps again.
Any suggestions?
Scott Fella Fri, 08/15/2008 - 09:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I have a Linsys600N and can only get around 130mbps and that is sitting next to the ap. A Mac book got the same link speed, but had a higher throughput than what I was getting on the 600N. Why does it drop... who knows, I think when they get something standard instead of a draft, things will work better. Try using different channels and play around with the 600N card settings, that is what I did.
zhenningx Fri, 08/15/2008 - 09:18
My Macbook also gets 130Mbps. Maybe an issue with 300N card.
Scott Fella Fri, 08/15/2008 - 09:26
  • Hall of Fame,
    2017 Wireless
It can be.... use iperf and test the throughput.... that is another thing you will be amazed with.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
