gk/ipipgw to gk/ipipgw
Aug 15th, 2008
In the following setup:
vct - gk/ipipgw - fw - internet - fw - gk/ipipgw - vct
2 vct's are registered on a gatekeeper with integrated ipipgw (cube) on 2 different locations. When setting up a session from vct1 to vct2 the call is terminated on the incoming call leg with a normal call clear.
attached the config on the receiving gk/ipipgw and the outcome of: sh gatek call.
The config of GK1 is similar.
Any ideas why the call isn't passed on two the outgoing call-leg?
Marwan ALshawi Fri, 08/15/2008 - 07:23
as i can see there is firewall in the path
have enabled the h323 signaling thorugh these firewalls and have enabled h323,h225 inspection ??
tonny.ausema Mon, 08/18/2008 - 23:00
Thanks for your suggestion. There is a h323 enabled firewall between the 2 BE's passing h323, h225. And I can actually see the call comming in on the 1st call leg of the 2nd BE but it terminates there.
