Another VM to UM Question
Aug 15th, 2008
Guys
i know there are a lot of posts already there about this however i just wanted to put my scenario on the board to have a more general stepped approach to our upgrade.
here is the scenario
We had unity 4.0 on an old MCS 7825 server 200 users. this was VM Only and exchange etc was installed on the unity server.
about 6 months ago the customer bought a new server and we migrated this solution to the new servers. same config and still VM only.
the customer just bought UNTY 5 UM and we need to install that on the new server.
so my question is the following
1. what are the steps for us to upgrade from vm TO UM without disruption - our AA resides on the existing unity.
2. im not too clear on how the exchange part works. as it is now, we installed exchange on the same box, with UM we are to use the customer's Exhange. How does the upgrade actually work.
basically this is how i was looking at it
1. Contact cisco and ask them to reissue VM User licenses so i can place on our old server (so i can work with the new server offline)
2. rebuild the new server with required OS and install same 4.0 version and then re-migrate users
3. Upgrade to 5.X and establish new partner exchange server 2007 that resides on customer network.
4. Place new server back into production.
Whats also a little grey is when rebuilding the new server, do i still install exchange locally to the unity and have it in its own workgroup...little confused :)
any help as usual would be greatly appreicated.
sorry if im rambling
Overall Rating: 4 (1 ratings)
milucero Wed, 08/20/2008 - 11:42
to answer your questions;
1.) very hard without having an extra server,(would be best if you had one more server and leave what you have now in place) you can try the method you mentioned, I would take a DiRT backup from what you have now, and then restore to this old server you mentioned, also follow what I have listed below, to minimize the outage.
2.) No real upgrade, you will be reinstalling from scratch because you are changing domains.
3.) see #2
with the new 5.0 server, no you do not install exchange on the server, only the 2003 Exchange tools.
Not to discourage you, but this is gonna be a long process and you need to really plan for this, a lot can go wrong, so yeah be sure to open a TAC case.
The hard part here is the fact that you have a VM solution all on box, and I am assuming the exsisting customer Exchange is in a seperate domain than the VM only box. At a high level you will have to use ExMerg (Microsoft tool) if you want to transfer the old voicemail they have saved to the new UM environment, which is gonna be tricky with two different domains, I would recommend to leave the old server in place after the UM conversion, assign it a different pilot number, and tell the users to access their saved VM, 'dial XXXX' and that it will be decomissioned after a period of time.
As far as no interuptions, if this is really a critical factor, I would suggest a cold cut over, meaning, leave the current server inplace, install the new 5.0 on a different server, import all the users from the off box Exchange server using Bulk Import tool, integrate this fully with the CCM but do not change the pilot number in everyones Vm profile yet, first test everything and when you are ready you just go in and change the VM profile to point to the new Unity server.
Hope this helps
a.gooding Wed, 08/20/2008 - 12:12
wow thanks for that reply, got me scared now :)
well we do have an old server and i just migrated all the info to that server and that is fine so we have cutover the old server already and now i can work with the new.
so now im starting to plan.
tell me if im wrong here.
First, i saw that you could use a new tool called COBRAS instead of DIRT.
second the plan is (and pleasssse tell me if im going wrong here), since i have the exchange on the unity, migrate the exchange to the existing customer exchange (basically moving the exchange out and placing onto customer domain.
then i can install 5.X and use COBRAS to restore messages and call handlers.
obviously im seeing a zillion grey areas here but am i even getting a little warm ?
Obviously im going to LAB everything here before i even attempt to do this
milucero Wed, 08/20/2008 - 12:23
As far as migrating the old Exchange, do you really have a lot of voicemail that needs to be saved?
The biggest issue is the separate domains, you cant just change that in Unity, you have to reinsatll everything.
I am assuming that all your users have accounts for email in the 2007 environment, so to get them on the new Unity server you will just import them, so no real need to transfer/move their accounts from the old to teh new.
The problem with the COBRAS is that it is beta only, so no TAC or BU support, Jeff Lindborg will help as best he can, but he is a very busy guy.
One option that you do have, is upgrade your current server to 5.0, take a DiRT back up saving voicemail and all settings and then restore to your new server which is integrated to the 2007 server. This should work, as long as the users alias's match on both servers.
Mike
a.gooding Wed, 08/20/2008 - 12:37
ok ill have to do some reading and testing before i start asking any more questions because ive already smoked too much cigarettes on this :)
a.gooding Thu, 08/21/2008 - 09:33
just to advise. the customer said they would rather a fresh installation and dont worry about existing messages or personal greetings as they intend to standardize on this as well :) the only thing i need to retain are the call handlers for thier Auto Attendant.
makes the job much easier but im still gonna spend some time migrating all subscribers in teh lab to ensure that the next time around i can post answers instead of questions
thanks again
