Farrukh Haroon Fri, 08/15/2008 - 07:06
  • Red, 2250 points or more
"Specific messages" requirements can be met with logging lists. You create a logging list, define the email logging settings and then associate a logging list with the mail logging. Not so sure about the 'specified time' requirement. That would most probably involve scripting that would login to the box at the desired start time, enable the mail logging and then login again to disable it at the desired stop time.
Have a look at:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805a2e04.shtml#use
Farrukh
cisco24x7 Fri, 08/15/2008 - 07:26
  • Silver, 250 points or more
The solution is very simple:
1- send all your log from the ASA over to a Linux syslog server,
2- There are utilities to filter the log
message for you in Perl or shell. In other
words, the utility looks at the log in
real-time and can filter specific messages
you want to see,
3- configure it to send you email at whatever
time you want. That can be done with crontab
There is no need to log into the ASA itself.
If you write a script to log into the ASA,
you then have to store the username/password
in a script and that is a security risk.
With the syslog message, you don't have to store any username/password anywhere.
Easy right?
