How to block a incomplete origin code route in BGP
Aug 15th, 2008
Hi Fellow Networkers,
I was trying to block a BGP route with incomplete origin code(?) but got no luck.
i tried route-map but there is no match statement for origin code, i also tried regular expression but still it didn,t work...
Routers are connected in below mentioned fashin.
R1 <---> R2 <---> R3
BGP route is coming from R1 and i am stopping it on R3.
any help really appreciated.
Giuseppe Larosa Fri, 08/15/2008 - 07:55
Hello Mohinder,
? is a special character in reg exp.
try to use \? to say you want match exactly char '?'
Hope to help
Giuseppe
mohindersingh Fri, 08/15/2008 - 12:53
Hi Guisiar,
Thanks for the reply.
but how to stop the incomplete route..normally regular expression we use with as-path acccess list. but we have to stop a route with incomplete origin code so we can,t use regular expression.
do you know any method to block origin code with regular expression.
Mahi
Giuseppe Larosa Fri, 08/15/2008 - 13:23
Hello Mahi,
what you write inside an as path list is actually a regular expression
define an as path list that matches ? at the end of as path
use the as-path access-list inside a route-map
route-map stop-incomplete deny 10
match as-path X
match ip address
route-map stop-incomplete permit 20
empty block to permit all other routes
apply the route-map inbound on R3 on the BGP session with R2 and you should get the result.
Hope to help
Giuseppe
