PPP multilink bundle max-interface configuration
Aug 15th, 2008
Hi Fellow Networkers,
I am bundling two E1 lines in a PPP multilink bundle. need to check the command reuqired to configure on multilink interface so that if any E1 goes down, bundle shld go down.
I am trying to shut a interface manually but ppp is just removing that interface from bundle but still the link is up?
Any help is really appreciated
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 08/15/2008 - 08:00
Hello Mohinder,
in the multilink config you need to specify the minimum links to be up to stay up
so the command should be
ppp multilink min-link 2
ppp multilink links minimum 2 (IOS 12.2 or higher)
Hope to help
