Mars box MARS box v4.3.5 (2838) IPS Signature Version 330 upgrade
Aug 15th, 2008
  • Bronze, 100 points or more
Hi, I have the software MARS box v4.3.5 (2838) IPS Signature Version 330
Is there any upgrade available for it?
Where can I found info for upgarding the software and IPS Signature on Cisco Web Site?
I also want to integrate CiscoWorks, LMS 2.6 to sent SNMP Trap Notification to the MARS box v4.3.5 (2838) IPS Signature Version 330. Is it possible and what would be the port # on the MARS box?
Farrukh Haroon Fri, 08/15/2008 - 22:49
  • Red, 2250 points or more
You are already running the latest software for the Generation 1 MARS appliances. You can find newer updates here:
http://www.cisco.com/cgi-bin/tablebuild.pl/cs-mars
For IPS, it is better to turn on automatic updates. Just go to:
Admin >> System Setup >> IPS Signature Dynamic Update Settings
The URL is already set there, just put your CCO username/password and click 'Update Now' then hit 'Submit'. I think the current Signature release is 352. You can manually downlaod them from here if you like:
http://www.cisco.com/cgi-bin/tablebuild.pl/mars-ips-sigup
Please rate if helpful.
Farrukh
