out of sync problem caused by crypto key
Aug 15th, 2008
I have 50 devices out of sync problem caused by crypto key. i have used the porcess posted on this forum. change the transport sequence to telnet then ssh instead of tftp. I have checked the "show running-config brief" working on device.but still have a problem. any suggestion greatly apperciated.
Joe Clarke Fri, 08/15/2008 - 08:56
RME must not be detecting that "show running-config brief" is working. In order to determine that, you will need to post the output of show running-config brief. If you cannot do that, then you'll need to open a TAC service request with that information.
eliaspaulos Fri, 08/15/2008 - 09:59
Thanks J. for security reason I have opened TAC case as your recommendation.
