Switch Stack failure notification
Aug 15th, 2008
I'm looking for suggestions on monitoring for failure of a switch in a stack. I use WhatsUp for monitoring and the basic "ping" would not detect if a member switch were to fail.
Giuseppe Larosa Fri, 08/15/2008 - 08:43
Hello Tim,
you would need to create a script that has to do the following:
telnet to the stack
issue sh switch
collect output
verify that you have the expected number of Ready on it
see
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
or use snmp traps
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_40_se/command/reference/cli3.html#wp1944901
snmp-server enable traps fru-ctrl
(Optional) Generate entity field-replaceable unit (FRU) control traps.
>>In the Catalyst 3750 switch stack, this trap refers to the insertion or removal of a switch in the stack.
Hope to help
Giuseppe
ropethic Fri, 08/15/2008 - 09:53
I know of customers using solarwinds orion to monitor the stack. When discovering the device snmp is able to identify the stack and report status and traffic using SW orion
I would try a freeware snmp poller such as MRTG.
