remote VPN error
What could be the problem for getting the error when trying to connect to VPN gateway through client,
6|Aug 15 2008|16:51:22|302014|||Teardown TCP connection 327321 for outside: to NP Identity Ifc: duration 0:00:04 bytes 0 TCP Reset-I
Farrukh Haroon Sun, 08/17/2008 - 03:21
This means that your clients are using IPSEC over TCP (Port 10000) to connect to the VPN GW. However the higher security level interface (represented by 'I' in Reset-I) is sending a reset to close the connection. This is usually normal (as one side is requesting to close the TCP session), perhaps it does not need it any longer.
If your VPN is not working, you would be better of running an isakmp/ipsec debug then worrying too much about this syslog.
Please rate if helpful, Regards
