ASA and WAAS
mlouis
Does the ASA support WCCP Service 61 redirection? What are the limitations for using ASA instead of routers for redirection with WAAS?
Zach Seils
Level 7
Level 7
If the service group 61 you are using is Cisco WAAS, then the answer is no. The ASA WCCP implementation does not support WCCP services that spoof the client IP address.
Zach
ropethic
Level 4
Level 4
The ASA supports WCCPv2, 32 WAEs per group, 1 Pix per group, GRE-redirect / return and ingress redirect return
Following platforms supported:
Cisco ASA 5500, SecurePIX 515, 535.
I will forward the config guide in a bit
Rob
ropethic
Level 4
Level 4
Here is the configuration link for WCCPv2 configuration
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/dhcp.pdf
Zach Seils
Level 7
Level 7
Zach
